Alerting for Linux Processes
  • bkimura
    • Mar 2019
    • 14
    Newbie here. I created a new item for a Linux server in order to monitor a process. ( proc.num[cron] to monitor for the cron process ) This seems to be working as when I look at the Latest data I see that there is Last value of 1 and when I shutdown the cron daemon on the host, the Last value changes to 0. Ok, this is all good with the exception that I'm not seeing any alerts indicated in the dashboard when I shutdown cron. What do I need to do in order for this item to generate an alert when Cron is not running? Thank you!
    - Bill
  • LenR
    • Sep 2009
    • 1011
    You need a trigger with rules for that item.
