Good day,
As described in the Documentation: "Before changing the status of the '...' trigger, Zabbix will check for corresponding trigger dependencies. If found, and one of those triggers is in 'Problem' state, then the trigger status will not be changed."
The question is, will the trigger status not be changed only from "OK" status to "PROBLEM" or also from "PROBLEM" to "OK"?
