Hello everyone !
I have another question about the Dashboard.
For example, I have a main Dashboard, on which I will output a problem. There we have the Problems widget. Here there was a problem with the disk space C.
How to make it so that when you click on the host name (where the ping appears, tresroute) there was a transition to a dashboard with this host?
2 questions
Dynamic list on global view.
Immediately to the question .. For example, there are 100 servers, they are all added to zabbiks. And here you only need to finish the Global View, to make a list like this:
And when a problem appears on any server, it automatically bounces up the list so that it does not need to scroll through the entire list. This can be implemented as standard zabbiksom or is there an option for grafana?
Thank!
2 questions
| PC name | RAM | CPU | Internet | Disk C: |
| test | test | test | test | test |
Thank!
