Zabbix get history data
  • qq89267388
    • Mar 2019
    hi
    i use zabbix 4.0
    i want use zabbix history data to generate a report,the time range is one week.
    when i use zabbi API to get data ,i find the speed is very slow
    but i noticed that when i use grafana to generate one week graph,the speed is very fast .
    i look i get the zabbix data,find the data inteval about 10s, but the grafana graph the interval is much larger than 10s
    so i think whether zabbix api has some parameter to tell zabbix return data interval ???
  • LenR
    • Sep 2009
    • 1011
    I think I remember reading that Grafana caches the zabbix API calls, so it's probably only getting the recent history when you view a graph. It probably uses similar graph presentation as zabbix so you don't see each 10 sec interval.
    A weeks data at 10 sec intervals is a lot of rows, would trends provide the info?
