First start
  • muove
    • Aug 2006
    First start
    Hi
    I see this message if i run zabbix server
    root@monitoring /# zabbix_server
    zabbix_server: error while loading shared libraries: libnetsnmp.so.10: cannot open shared object file: No such file or directory
    but i have libnetsnmp.so.10 in /var/lib
    what is wrong ?
    what can i do ?
    OS: Trustix 2.2
    Zabbix 1.1
    net-snmp 5.3.1
  • xaitax
    • Apr 2006
    • 39
    Did you take a look where he is searching for the library? Normally in `/usr/lib'.
    [xai@w00t bin]# ldd zabbix_server | grep snmp
            libnetsnmp.so.5 => /usr/lib/libnetsnmp.so.5 (0xb7f60000)
    - xai
    • muove
      • Aug 2006
      root@monitoring /bin# ldd zabbix_server | grep snmp
      no such file or directory
      libnetsnmp.so.10 in usr/lib
      • xaitax
        • Apr 2006
        • 39
        You see, you solved your problem by yourself.
        - xai
        • muove
          • Aug 2006
          big big thanks
          i resolve problem
          ldd zabbix_server
          show which of library not found
          strace zabbix_server (for sun truss zabbix_server)
          show where zabbix_server want fint library
          put library in your place
          that all
