store the data metrics from Zabbix agent in milliseconds resolution insted of minutes
  • vamshi_pulluri
    • Mar 2019
    I want different data metrics like CPU utilization, memory utilization from Zabbix agent with milliseconds resolution instead of minutes resolution.
    I am using Zabbix Python API to retrieve metrics from Mysql Zabbix database and noticed that data is stored with minutes resolution, which is as shown below:
    PHP Code:
     Sl.NO Date Value
    1 Monday
    March 252019 04:22:07 0.0700
    2 Monday
    March 252019 04:23:07 0.0600
    Is it possible in Zabbix to store the data metrics with milliseconds (or nanoseconds) resolution. If yes, how should I do that.
  • brunohl
    • Mar 2019
    • 215
    I've never used it, but is specified in the docs that this is possible:
    You should use the "ns" field, that specifies "Nanoseconds when the value was received."
