zabbix - cpu process info
  • glardz
    • Oct 2018
    • 45
    hello,
    i want want to monitor cpu process in os windows, i know proc.cpu.util[Sqlsvr.exe] is not supported by zabbix agent, i tried this key perf_counter[\Process(explorer)\% Processor Time] but not work, do you have some idea,
    thanks
  • brunohl
    • Mar 2019
    • 215
    The key "proc.cpu.util[Sqlsvr.exe]" would not work, due to not working in Windows.
    For the other key ("perf_counter[\Process(explorer)\% Processor Time]"), try running it with zabbix_get, like this:
    zabbix_get -s YOUR_HOST -k "perf_counter[\Process(explorer)\% Processor Time]"
    • glardz
      • Oct 2018
      • 45
      how can i use, why there are no processes cpu usage ?
      • glardz
        • Oct 2018
        • 45
        i tried this key perf_counter[\Process(svchost)\% Processor Time] but i have 0, i don't know why ?
