Zabbix - Monitoring Network - Doubts
  • mgfeal
    • Mar 2019
    Hi all!
    I am new using Zabbix. I downloaded the appliance version to do some test. I detected some problems with the internet connection of my webpage housing, so I want to monitoring it externally. I only want to monitor ping responses.
    The appliance uses Zabbix 4.0 LTS.
    I added a new host. Then I added "Template Module ICMP Ping". This template automatically adds 3 triggers.
    Now I have some doubts. I see that Zabbix triggers uses seconds to measure time, not miliseconds. How can I change it? How do you monitoring network?
    Thanks!!
