Hyper-V2008R2 net.if.in failure
  • Golf2
    • Jun 2014
    • 11
    Hello all,
    i´m from germany and i have a problem with a virtual machine on hyper-v 2008r2.
    In Zabbix i can read every network traffic from normal servers that arent virtual machines. So Zabbix works fine.
    normaly the key in the Items menu looks like
    net.if.in["BASP Virtual Adapter"]
    in the virtual Servers looks like
    net.if.in["Netzwerkkarte für Microsoft Virtual Machine-Bus"]
    I think, its a problem with the virtual network interface and / or the name of the virtual network interface. "Netzwerkkarte für Microsoft Virtual Machine-Bus". Because only in german the öäü exist.
    I get the Network name with "route print" so it will be ok.
    Anyone can help me?
    Thx
  • ingus.vilnis
    • Mar 2014
    • 908
    Hello and welcome!
    As from Zabbix documentation: Multi-byte interface names on Windows are supported since Zabbix agent version 1.8.6.
    (https://www.zabbix.com/documentation...s/zabbix_agent)
    What agent version do you use then?
    Did you create this item by yourself or was it created by a low level discovery rule? I somehow doubt that the problem in your case would be in interface name due to German specific characters.
    Best Regards,
    Ingus
    • Golf2
      • Jun 2014
      • 11
      Hello ingus,
      i use a Zabbix 2.2 VHD Appliance.
      As Agent i use 2.2.3.
      I create the item by myself.
      On physical Host it works normaly, only at the hyper-v clients it doesnt work.
      I can check CPU Load and other stuff on Hyper-V Clients (2008r2, W7, WXP) only the network statics doesnt work.
      • ingus.vilnis
        • Mar 2014
        • 908
        Hello!
        Does Zabbix show this item as "Not supported"?
        Can you try to check this item with zabbix_get utility?
        (https://www.zabbix.com/documentation...ges/zabbix_get)
        On your Zabbix server run the command:
        zabbix_get -s <host name or IP> -k net.if.in["Netzwerkkarte für Microsoft Virtual Machine-Bus"]
        You can also try running zabbix_agentd command on your monitored host to see if maybe there is a problem with the interface name.
        (https://www.zabbix.com/documentation.../zabbix_agentd)
        zabbix_agentd -t net.if.list
        Best Regards,
        Ingus
        • Golf2
          • Jun 2014
          • 11
          Hello Ingus,
          thx for ur help.
          1. Yes i get the message "Not Supported" at the Item
          2. I get the Error " Zabbix_get [3412]: Get value error: ZBX_TCP_READ<> failed: [0x00002746] Eine vorhandene Verbindung wurde vom Remotehost geschlossen.
          3. If ein run the command, i get the name of networkinterfaces back but there doesnt looks like "Netzwerkkarte für Microsoft Virtual Machine-Bus".
          Its "Netzwerkkarte f┬│r Microsoft Virtual Machine-Bus"
          So i think its a Problem with german ü letter.
          4. Now i have change the interfacename to
          net.if.in["Netzwerkkarte f┬│r Microsoft Virtual Machine-Bus"]
          But same error. "Not supported"
          If i start ur command from 2. with the cryptic interfacename, i geht another error back. It calls
          zabbix_get [3344]: Get value error: ZBX_TCP_WRITE() failed: [0x00002745] Eine bestehende Verbindung wurde softwaregesteuert durch den Hostcomputer abgebrochen.
          • Golf2
            • Jun 2014
            • 11
            LOL, ok problem is fixed.
            Quick and Dirty
            net.if.in[172.xxx.xxx.xxxx]
            With the IP of the host (2008R2 virtual client) it works fine..... somtimes it will be so easy.
            Thx for ur help.
            • ingus.vilnis
              • Mar 2014
              • 908
              Hello!
              Really good solution! Simple and beautiful.
              Glad that it works now!
              Ingus
              • Golf2
                • Jun 2014
                • 11
                Hi All,
                now i have another Problem with net.if.
                For a few computer my soloution works fine
                But for a template it wont work. So i use a variable it looks like
                net.if.in[{HOST.CONN1}]
                The Problem is, net.if.out[{HOST.CONN1}] show me a wrong speed. They show me only 20MB/s, the first solution shows me the right speed of 75MB/s.
                The variable {HOST.CONN1} used the ip from Host Agent Interface? Right? Or who can i get the right IP variable?
                Thx for ur help.
                • Golf2
                  • Jun 2014
                  • 11
                  The Problem is unchanged.
                  • Golf2
                    • Jun 2014
                    • 11
                    • ingus.vilnis
                      • Mar 2014
                      • 908
                      Hello!
                      Please check if you have only one agent IP interface on the host that shows the wrong speed. I you have multiple agent interfaces, it is very likely that {HOST.CONN1} uses the wrong interface.
                      Best Regards,
                      Ingus
