Hello Zabbix community!
This problem happens to me for the 2nd time. After upgrading Zabbix, the dashboard has the error, mostly I could not use any links, only can adjust the refresh time. Check the attachment, it is the right-top corner of my Zabbix frontend.
This time I can not fix it, previous time I logout once, then OK.
I test upgrade 4.0.5 > 4.0.6 twice, and one is fresh installation of 4.0.5. BTW, even I create a new widget, still no use. Dashboard can not work.
Please comment. I had a quick search in the forum, seems nobody has same problem?
