Problem after upgrade from 4.0.6 to 4.2
  • ChiefPilot
    • Jul 2012
    • 10
    Help, please, who can. Made an upgrade from 4.0.6 to 4.2 and got the following:
    [Z3005] query failed: [1071] Specified key was too long; max key length is 767 bytes [create unique index lld_macro_path_1 on lld_macro_path (itemid,lld_macro)]
    in server log. The base can not upgrade to 4020000. What can I do here? mysql: Ver 15.1 Distrib 10.0.38-MariaDB, for debian-linux-gnu (x86_64) using readline 5.2
  • kloczek
    • Jun 2006
    • 1771
    On mysql 5.7.25 everything went smoothly ..
    • holantomas
      • Apr 2019
      Hi guys, I have same issue
      DB is:
      10.1.38-MariaDB-0ubuntu0.18.04.1 Ubuntu 18.04
      I Tried to change file format, without any progress
      MariaDB [(none)]> show variables like "%innodb_file%";
      | Variable_name            | Value     |
      | innodb_file_format       | Barracuda |
      | innodb_file_format_check | ON        |
      | innodb_file_format_max   | Barracuda |
      | innodb_file_per_table    | ON        |
      4 rows in set (0.00 sec)
      The bad thing on this is I cannot rollback to 4.0.6 cause, "Wrong DB mandatory version"
      • Atsushi
        • Aug 2013
        • 2028
        Are you using utf8 as database character set?
        ex.
        MariaDB [zabbix]> show variables like 'char%';
        | character_set_client     | utf8                       |
        | character_set_connection | utf8                       |
        | character_set_database   | utf8                       |
        | character_set_filesystem | binary                     |
        | character_set_results    | utf8                       |
        | character_set_server     | utf8                       |
        | character_set_system     | utf8                       |
        | character_sets_dir       | /usr/share/mysql/charsets/ |
        8 rows in set (0.00 sec)
        MariaDB [zabbix]>
        • holantomas
          • Apr 2019
          Hi, thx for reply
          and yes. I forgot say that I'm using docker images.
          I don't know how but there can be problem when using utf8mb4. But I cannot remeber how was DB created(I think, by automatic script in docker image).
          Should I collate it to standard utf8?
          | character_set_client     | utf8mb4                    |
          | character_set_connection | utf8mb4                    |
          | character_set_database   | utf8mb4                    |
          | character_set_results    | utf8mb4                    |
          | character_set_server     | utf8mb4                    |
          8 rows in set (0.01 sec)
          • holantomas
            • Apr 2019
            Don't worry,
            I already fix that.
            first changed
            default_character_set_name
            to "utf8" and COLLATE to "utf8_general_ci"
            Than check tables charset and found that all tables already have utf8 but upgrade script create one table with default utf8mb4.
            So changed table charset to utf8 and utf8_general_ci.
            Server successfully upgraded and working.
            Thanks for point me out
            • kloczek
              • Jun 2006
              • 1771
              Quick search for "Specified key was too long; max key length is" using google
              First link from the list https://stackoverflow.com/questions/...h-is-767-bytes
              Looks like you are usung quite old DB engine.
              If that is the cause your issue can be solved by mysql upgrade => it has nothing to do with zabbix per se.
