installation error
  • francly
    • Jun 2014
    installation error
    Hi, I need help to take a look the problem on the installation, I have tried change the permission but still no luck.
    first is the open base dir error
    second is the config file error
    I installed this on the zpanel, I make the soft link to the webroot.
    [root@ web]# ls -als
    total 12
    4 drwxrwxrwx 2 root root 4096 Jun 8 12:45 .
    4 drwxrwxrwx 4 root root 4096 Jun 8 12:46 ..
    4 -rwxrwxrwx 1 root root 429 Jun 8 12:45 zabbix.conf.php
    [root@do1 web]# pwd
    /etc/zabbix/web
    [root@ web]# cd /var/zpanel/hostdata/zadmin/public_html/
    [root@ public_html]# ls -als
    total 16
    4 drwxrwx--- 4 apache apache 4096 Jun 8 12:20 .
    4 drwxrwx--- 4 apache apache 4096 Jun 2 01:13 ..
    0 lrwxrwxrwx 1 root root 18 Jun 8 12:20 zabbix -> /usr/share/zabbix/
    [root@do1 public_html]#
  • ingus.vilnis
    • Mar 2014
    • 908
    Hello and welcome!
    Why are you trying to install the very old Zabbix version 1.8.20 when there is much better version 2.2.3 available?
    Best Regards,
    Ingus
    • francly
      • Jun 2014
      Originally posted by ingus.vilnis
      Hello and welcome!
      Best Regards,
      Ingus
      Thanks, I install through the yum install.
      So the new version can resolve the problem?
      • bagni
        • Mar 2012
        • 164
        you must put the config path within the allowed path:
        /var/zpanel/hostdata/zadmin/public_html/zabbix/
        Fix your config file (<zabbix web path>/include/config.config.php):
        PHP Code:
        $ZBX_CONFIGURATION_FILE = './conf/zabbix.conf.php';
        and check the write capability for webserver's user into /usr/share/zabbix/
        Bye Lorenzo
        p.s.: you are using a quite old zabbix version, latest release cannot let to define the zabbix.conf.php because must reside into web directory.
        • ingus.vilnis
          • Mar 2014
          • 908
          Here is pretty good manual on how to install the very latest version. (https://www.zabbix.com/documentation..._from_packages)
          Best Regards,
          Ingus
          • francly
            • Jun 2014
            Best Regards,
            Ingus
            Thanks all of you, I follow the instruction and I can complete the setup.
