Trigger question/assistance
  • rkruck
    • Mar 2014
    • 9
    I have set triggers for disk space for when it reaches 80%, 90% and 95%. The problem is because the trigger I set for 95% is:
    {Template OS Linux:vfs/fs/size[{#FSNAME},pfree].last(0)}<5
    I am getting 3 alerts and emails for it being less that 20, less than 10 and less than 5. If I wanted to islolate the triggers to only alert if they were between say 20-10, 9-5, and 4 or less is there a way to do it so you only get one alert depending on how full it is?
    I hope this is making sense.
    Robert
  • coreychristian
    • Jun 2012
    • 159
    I have my triggers setup to do what your looking for, there might be a better way though.
    {Template OS Linux:vfs.fs.size[{#FSNAME},pfree].last(0)}<15&{Template OS Linux:vfs.fs.size[{#FSNAME},pfree].last(0)}>10
    This trigger will fire when the last value is between 15 and 10, once it's less then 10% free this trigger clears.
    You will still receive an e-mail if the file system slowly grows through your thresholds, though you should stop getting e-mails for the trigger once it passes through the specific threshold.
    • aib
      • Jan 2014
      • 1615
      one more option - you can make in "dependent"
      20% trigger depend on 10% and 5% triggers
      10% trigger depend on 5% trigger
      When the 5% trigger active, 10% and 20% triggers don't activate.
      Sincerely yours,
      Aleksey
