Hi!
I'm trying to send alerts using Telegram
I created a bot and a group. It's all ok.
Use Telegram it's easy. If you browse:
Your message is sent.
Now I want to launch this wget command when a problem appear.
How can I do it?
I'm testing doing this:
Administration - Media type
Type: Script
Script name: telegram.sh
In /usr/lib/zabbix/alertscripts I created a telegram.sh file with this code:
#!/bin/bash
wget "https://api.telegram.org/bot....../sendMessage?chat_id=-3......&text=test"
Then I changed chmod to 755 this file.
If I execute it, works perfect.
So, now I tried to configure the alerts.
In Administration - Users in Admin (user that I'm using) in Media added a new Media:
Type: Telegram
Send to: I don't know why I need to put some text in this box.
When active: 1-7,00:00-24:00
Use if severity: all checked
Enabled: checked
Now I force a problem. When the problem appears at Monitoring - Problems I don't receive the message.
Anybody can help me?
Thanks!!
How can I do it?
Type: Script
#!/bin/bash
Type: Telegram
Enabled: checked
Thanks!!
