problems with mysql on ubuntu server 14.04 LTS
  • pds
    • Apr 2014
    • 11
    I know this maybe the wrong forum to ask
    having problems with starting mysql on ubuntu server 14.04LTS
    /var/log/mysql/error.log below
    already tried to wellknown trick with ipdata
    mv ibdata1 ibdata1.bak
    cp -a ibdata1.bak ibdata1
    mysql error log below:
    140611 15:28:24 [Note] /usr/sbin/mysqld: Shutdown complete
    140611 15:28:24 mysqld_safe Number of processes running now: 0
    140611 15:28:24 mysqld_safe mysqld restarted
    140611 15:28:24 [Warning] Using unique option prefix key_buffer instead of key_buffer_size is deprecated and will be removed in a future release. Please use the full name instead.
    140611 15:28:24 [Warning] Using unique option prefix myisam-recover instead of myisam-recover-options is deprecated and will be removed in a future release. Please use the full name instead.
    140611 15:28:24 [Note] Plugin 'FEDERATED' is disabled.
    140611 15:28:24 InnoDB: The InnoDB memory heap is disabled
    140611 15:28:24 InnoDB: Mutexes and rw_locks use GCC atomic builtins
    140611 15:28:24 InnoDB: Compressed tables use zlib 1.2.8
    140611 15:28:24 InnoDB: Using Linux native AIO
    140611 15:28:24 InnoDB: Initializing buffer pool, size = 128.0M
    140611 15:28:24 InnoDB: Completed initialization of buffer pool
    InnoDB: Unable to lock ./ibdata1, error: 11
    InnoDB: Check that you do not already have another mysqld process
    InnoDB: using the same InnoDB data or log files.
    140611 15:28:24 InnoDB: Retrying to lock the first data file
    140611 15:30:04 InnoDB: Unable to open the first data file
    InnoDB: Error in opening ./ibdata1
    140611 15:30:04 InnoDB: Operating system error number 11 in a file operation.
    InnoDB: Error number 11 means 'Resource temporarily unavailable'.
    InnoDB: Some operating system error numbers are described at
    InnoDB: http://dev.mysql.com/doc/refman/5.5/...ror-codes.html
    140611 15:30:04 InnoDB: Could not open or create data files.
    140611 15:30:04 InnoDB: If you tried to add new data files, and it failed here,
    140611 15:30:04 InnoDB: you should now edit innodb_data_file_path in my.cnf back
    140611 15:30:04 InnoDB: to what it was, and remove the new ibdata files InnoDB created
    140611 15:30:04 InnoDB: in this failed attempt. InnoDB only wrote those files full of
    140611 15:30:04 InnoDB: zeros, but did not yet use them in any way. But be careful: do not
    140611 15:30:04 InnoDB: remove old data files which contain your precious data!
    140611 15:30:04 [ERROR] Plugin 'InnoDB' init function returned error.
    140611 15:30:04 [ERROR] Plugin 'InnoDB' registration as a STORAGE ENGINE failed.
    140611 15:30:04 [ERROR] Unknown/unsupported storage engine: InnoDB
    140611 15:30:04 [ERROR] Aborting
    140611 15:30:04 [Note] /usr/sbin/mysqld: Shutdown complete
    140611 15:30:04 mysqld_safe mysqld from pid file /var/run/mysqld/mysqld.pid ended
    140611 15:31:06 mysqld_safe Starting mysqld daemon with databases from /var/lib/mysql
    140611 15:31:06 [Warning] Using unique option prefix key_buffer instead of key_buffer_size is deprecated and will be removed in a future release. Please use the full name instead.
    140611 15:31:06 [Warning] Using unique option prefix myisam-recover instead of myisam-recover-options is deprecated and will be removed in a future release. Please use the full name instead.
    140611 15:31:06 [Note] Plugin 'FEDERATED' is disabled.
    140611 15:31:06 InnoDB: The InnoDB memory heap is disabled
    140611 15:31:06 InnoDB: Mutexes and rw_locks use GCC atomic builtins
    140611 15:31:06 InnoDB: Compressed tables use zlib 1.2.8
    140611 15:31:06 InnoDB: Using Linux native AIO
    140611 15:31:06 InnoDB: Initializing buffer pool, size = 128.0M
    140611 15:31:06 InnoDB: Completed initialization of buffer pool
    InnoDB: Unable to lock ./ib_logfile0, error: 11
    InnoDB: Error in opening ./ib_logfile0
    140611 15:31:06 [ERROR] Plugin 'InnoDB' init function returned error.
    140611 15:31:06 [ERROR] Plugin 'InnoDB' registration as a STORAGE ENGINE failed.
    140611 15:31:06 [ERROR] Unknown/unsupported storage engine: InnoDB
    140611 15:31:06 [ERROR] Aborting
    140611 15:31:06 [Note] /usr/sbin/mysqld: Shutdown complete
    140611 15:31:06 mysqld_safe mysqld from pid file /var/run/mysqld/mysqld.pid ended
    140611 15:31:47 mysqld_safe Starting mysqld daemon with databases from /var/lib/mysql
    140611 15:31:47 [Warning] Using unique option prefix key_buffer instead of key_buffer_size is deprecated and will be removed in a future release. Please use the full name instead.
    140611 15:31:47 [Warning] Using unique option prefix myisam-recover instead of myisam-recover-options is deprecated and will be removed in a future release. Please use the full name instead.
    140611 15:31:47 [Note] Plugin 'FEDERATED' is disabled.
    140611 15:31:47 InnoDB: The InnoDB memory heap is disabled
    140611 15:31:47 InnoDB: Mutexes and rw_locks use GCC atomic builtins
    140611 15:31:47 InnoDB: Compressed tables use zlib 1.2.8
    140611 15:31:47 InnoDB: Using Linux native AIO
    140611 15:31:47 InnoDB: Initializing buffer pool, size = 128.0M
    140611 15:31:47 InnoDB: Completed initialization of buffer pool
    140611 15:31:47 [ERROR] Plugin 'InnoDB' init function returned error.
    140611 15:31:47 [ERROR] Plugin 'InnoDB' registration as a STORAGE ENGINE failed.
    140611 15:31:47 [ERROR] Unknown/unsupported storage engine: InnoDB
    140611 15:31:47 [ERROR] Aborting
    140611 15:31:47 [Note] /usr/sbin/mysqld: Shutdown complete
    140611 15:31:47 mysqld_safe mysqld from pid file /var/run/mysqld/mysqld.pid ended
