Run TagUI script and supervise it
  • VincheZ
    • Mar 2019
    • 9
    Hi everyone !
    I'm trying to execute a TagUI script on the Zabbix server.
    I created a Zabbix agent item which is doing:
    system.run[sudo /usr/local/share/applications/zabbix/tagui/src/tagui /usr/local/share/applications/zabbix/tagui/src/dev/1_argos]
    And a trigger linked to it which is checking if the return text is containing a text "ERROR":
    {Zabbix server:system.run[sudo /usr/local/share/applications/zabbix/tagui/src/tagui /usr/local/share/applications/zabbix/tagui/src/dev/1_argos].iregexp(ERROR)}<>0
    Into the Items and Triggers menu, there is no alert and everything is as OK.
    But when I'm looking into Lastest Data menu, there is no data for this trigger...
    Can I have some help with this problem ?
    I'm using Zabbix 4.2.0
    Tell me if you need more info.
    Thank you all.
