Hot to uptade a group via API using host.uptade?
  • Murilo Scarpa Sitonio
    • Feb 2019
    I'm trying to uptade the groups of a host via API but I'm getting an error ("code": -32602, "message": "Invalid params.","data": "Incorrect method "host.uptade".") even though my request is (seemingly) correct.
    Request:
        "jsonrpc": "2.0",
        "method": "host.uptade",
        "params": {
            "hostid":"10829",
            "groups":[
                    "groupid": "112"
                    "groupid": "11"
        "auth": "86a4c40265bf314e43b0c2de2be3bbe1",
        "id": 1
    What am I missing? Any help is appreciated!
    Thank you.
  • brunohl
    • Mar 2019
    • 215
    To me it seems correct. Are you sure that those ids are correct?
      • Feb 2019
      Yes, absolutely.
      I actually accomplished this task using host.massadd method. I don't understand why host.update nor host.add doesn't work...
