History of problems
  • 1berto
    • Sep 2018
    • 182
    History of problems
    For how much time zabbix keep the record of a problem?
    I'm trying to search for problems for hosts, but i only found 'active' problems.
    When problems are solved they are deleted?
  • brunohl
    • Mar 2019
    • 215
    You should go into "Monitoring >> Problems", then open "Filter" section and ask for history, like the image:
