disable pam logging for agent
  • chubbypiper
    • Apr 2019
    I am getting a lot of messages in journalctl from pam for all the sudo runs that the agent does. I saw https://unix.stackexchange.com/quest...ic-user/224444 for information on how to disable it, but it wasn't very successful. This is the contents of /etc/pam.d/sudo:
    [root@Sisko pam.d]# cat sudo
    #%PAM-1.0
    session [success=1 default=ignore] pam_succeed_if.so quiet ruser = zabbix-agent
    auth        include        system-auth
    account        include        system-auth
    session        include        system-auth
    [root@Sisko pam.d]#
    However, I am still seeing entries in the journal for zabbix agent:
    [root@Sisko pam.d]# journalctl -b | tail -n 40
    Apr 15 20:48:16 Sisko sudo[469708]: pam_unix(sudo:session): session closed for user root
    Apr 15 20:48:18 Sisko sudo[469713]: zabbix-agent : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/systemctl status NetworkManager
    Apr 15 20:48:18 Sisko sudo[469713]: pam_unix(sudo:session): session opened for user root by (uid=0)
    Apr 15 20:48:18 Sisko sudo[469713]: pam_unix(sudo:session): session closed for user root
    Apr 15 20:48:19 Sisko sudo[469718]: zabbix-agent : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/systemctl status nfs-server
    Apr 15 20:48:19 Sisko sudo[469718]: pam_unix(sudo:session): session opened for user root by (uid=0)
    Apr 15 20:48:19 Sisko sudo[469718]: pam_unix(sudo:session): session closed for user root
    Apr 15 20:48:20 Sisko sudo[469724]: zabbix-agent : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/systemctl status ntpd
    Apr 15 20:48:20 Sisko sudo[469724]: pam_unix(sudo:session): session opened for user root by (uid=0)
    Apr 15 20:48:20 Sisko sudo[469724]: pam_unix(sudo:session): session closed for user root
    Apr 15 20:48:21 Sisko sudo[469732]: zabbix-agent : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/systemctl status org.cups.cupsd
    Apr 15 20:48:21 Sisko sudo[469732]: pam_unix(sudo:session): session opened for user root by (uid=0)
    Apr 15 20:48:21 Sisko sudo[469732]: pam_unix(sudo:session): session closed for user root
    Apr 15 20:48:22 Sisko sudo[469738]: zabbix-agent : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/systemctl status reflector
    Apr 15 20:48:22 Sisko sudo[469738]: pam_unix(sudo:session): session opened for user root by (uid=0)
    Apr 15 20:48:22 Sisko sudo[469738]: pam_unix(sudo:session): session closed for user root
    Apr 15 20:48:23 Sisko sudo[469743]: zabbix-agent : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/systemctl status smartd
    Apr 15 20:48:23 Sisko sudo[469743]: pam_unix(sudo:session): session opened for user root by (uid=0)
    Apr 15 20:48:23 Sisko sudo[469743]: pam_unix(sudo:session): session closed for user root
    Apr 15 20:48:24 Sisko sudo[469750]: zabbix-agent : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/systemctl status sshd
    Apr 15 20:48:24 Sisko sudo[469750]: pam_unix(sudo:session): session opened for user root by (uid=0)
    Apr 15 20:48:24 Sisko sudo[469750]: pam_unix(sudo:session): session closed for user root
    Apr 15 20:48:25 Sisko sudo[469756]: zabbix-agent : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/systemctl status sysstat
    Apr 15 20:48:25 Sisko sudo[469756]: pam_unix(sudo:session): session opened for user root by (uid=0)
    Apr 15 20:48:25 Sisko sudo[469756]: pam_unix(sudo:session): session closed for user root
    Apr 15 20:48:27 Sisko sudo[469762]: zabbix-agent : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/systemctl status systemd-timesyncd
    Apr 15 20:48:27 Sisko sudo[469762]: pam_unix(sudo:session): session opened for user root by (uid=0)
    Apr 15 20:48:27 Sisko sudo[469762]: pam_unix(sudo:session): session closed for user root
    Apr 15 20:48:28 Sisko sudo[469769]: zabbix-agent : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/systemctl status xrdp
    Apr 15 20:48:28 Sisko sudo[469769]: pam_unix(sudo:session): session opened for user root by (uid=0)
    Apr 15 20:48:28 Sisko sudo[469769]: pam_unix(sudo:session): session closed for user root
    Apr 15 20:48:30 Sisko sudo[469793]: zabbix-agent : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/systemctl status zabbix-agent
    Apr 15 20:48:30 Sisko sudo[469793]: pam_unix(sudo:session): session opened for user root by (uid=0)
    Apr 15 20:48:30 Sisko sudo[469793]: pam_unix(sudo:session): session closed for user root
    Apr 15 20:48:50 Sisko sudo[469816]: zabbix-agent : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/systemctl status display-manager
    Apr 15 20:48:50 Sisko sudo[469816]: pam_unix(sudo:session): session opened for user root by (uid=0)
    Apr 15 20:48:50 Sisko sudo[469816]: pam_unix(sudo:session): session closed for user root
    Apr 15 20:48:51 Sisko sudo[469821]: zabbix-agent : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/systemctl status lightdm
    Apr 15 20:48:51 Sisko sudo[469821]: pam_unix(sudo:session): session opened for user root by (uid=0)
    Apr 15 20:48:51 Sisko sudo[469821]: pam_unix(sudo:session): session closed for user root
    [root@Sisko pam.d]#
    I'm sure it's an order thing with my pam configs, but I'm not seeing what I'm doing wrong. Does anyone have any suggestions?
  • 1977er
    • Feb 2022
    Last edited by 1977er; 24-07-2022, 00:02. Reason: sorry, for quoting redundant information (link to stackoverflow)
    • mvrk
      • Oct 2008
      • 71
      I'm having the same issue, were you able to find a solution?
      • 1977er
        • Feb 2022
        No, I have not.
        • tim.mooney
          • Dec 2012
          • 1430
          Originally posted by 1977er
          No, I have not.
          The original poster's pam session entry is incorrect. They have 'ruser = zabbix-agent', but that's wrong. On most systems, especially systems using the official packages, the service account user is 'zabbix', so pam_succeed_if.so test should be 'ruser = zabbix'.
          • 1977er
            • Feb 2022
            Unfortunately this does/did not help in my case. My "ruser" setting has always been consistent with the zabbix account on the system.
            • PavelZ
              • Dec 2024
              • 171
              For templates with sudo, a typical configuration looks something like this:
              file : /etc/sudoers.d/zabbix_smartctl
              Defaults:zabbix !requiretty,!logfile, !syslog, !pam_session
              This eliminates typically useless spam in the logs.
