Trigger Problem
  • bnajem
    • Dec 2013
    • 14
    Trigger Problem
    i have zabbix version 2.0 on dashboard i have problem of apache availability since 15 days . i stopped apache for the server the trigger is fire and after i got the acknowledge but for the first alert(since 15 days ) still always on the dashbord and in the events list with status PROBLEM ,so i think that i must drop the event from the database but its not easy to find the appropriate id of event (there is a lot of events when i check from database )
    any Help PLZ ?
  • aib
    • Jan 2014
    • 1615
    Do I understand correctly, that the problem is still persist, you just hit "Acknowledge" button, right?
    If you don't like the event - you can disable that trigger and Item which control the availability of apache.
    If I'm understand you wrong, please, tell about a problem a little bit more.
    Sincerely yours,
    Aleksey
    • bnajem
      • Dec 2013
      • 14
      thank you aib for the response .
      the probleme is i dont like to see the alert on the dashboard of zabbix ,for the alert now is Acknowledged but its still on the interface on 'last 20 issues' like problem so like to remove it from database by sql request and i cant find the identifiant of this alerte how can I do these ? .
      • aib
        • Jan 2014
        • 1615
        "Acknowledgement" not fixing your problem
        It will be here until the problem will be resolved (ex. apache service started back)
        If you like to find event in DB - take a look on "Original Event ID" and use it to find the event in database.
        But it's short wrong way to solve your "Aesthetics issue"
        Sincerely yours,
        Aleksey
        • bnajem
          • Dec 2013
          • 14
          if i stop apache services the trigger fire and after restarting the services i recieved the Acknowledgement its fine no problem in this part ,but the real problem is always the first alert still on the dasboard of interface and not recived the Acknowledgement
