Sudo with zabbix Agent scripts
  • peterfm
    • Apr 2019
    I have read a lot of articles on the subject and I am not able to do that in centos 7 the zabbix agent can use sudo commands without disabling the selinux.
    I have installed the agent Zabbix, I have included the necessary permissions in the sudoers file so that the password is not required, but when trying to execute a script that makes a simple "sudo touch /opt/wildfly/standalone/deployments/wars.query2" an error is generated. If I deactivate selinux, everything goes fine, but if I try "tail -f /var/log/audit/audit.log | grep denied | audit2allow -M zabbix_agent_setrlimit; semodule -i zabbix_agent_setrlimit.pp" to generate the necessaries exceptions, I still get permission errors runing the script.
    Is it possible to get this without disabling selinux?
    Here is an example.
    • sudo touch /opt/wildfly/standalone/deployments/wars.query2
    • echo | sudo tee -a /opt/wildfly/standalone/deployments/wars.query3
    • sh: /usr/bin/sudo: Permission denied
    • sh: line 1: /usr/bin/sudo: Permission denied
    In Linux console, I can execute "sudo -u zabbix sudo touch /opt/wildfly/standalone/deployments/wars.query2" without any problem.
  • Atsushi
    • Aug 2013
    • 2028
    Did you configure requiretty?
    ex. by visudo
    Defaults:zabbix    !requiretty
    • kloczek
      • Jun 2006
      • 1771
      You need use system.run[] key https://www.zabbix.com/documentation...s/zabbix_agent or define UserParameter in zabbix agent configuration https://www.zabbix.com/documentation...userparameters
      • peterfm
        • Apr 2019
        ex. by visudo
        • Atsushi
          Atsushi commented
          Even though it can be run on the console, it requires special configuration when using the sudo command.
      • peterfm
        • Apr 2019
        Let me to do some tests about this and I'll post if it works.
        • bonne
          • Aug 2022
          Did you manage to solve this? I am facing the same issue - I can create an Item with key system.run that initiates a script on the server - it can "echo test", but when it come to something where it needs sudo, I get the same "/usr/bin/sudo: Permission denied"
          • j238267431
            • Nov 2022
            • 11
            Same for me, when I send command to zabbix-agent from zabbix-server zabbix_get -s 139.162.148.190 -k system.run["sudo systemctl restart nginx"]
            How can I fix this​
            • user1234
              • Jul 2022
              • 35
              Same for me
              someone have a solution?
              • j238267431
                • Nov 2022
                • 11
                try this https://unix.stackexchange.com/quest.../606476#606476
                polkit
                • parkerm17
                  • Nov 2022
                  For anyone finding this post, I found I had to do the following for Zabbix to run 'sudo shutdown' on a remote machine via an agent script:
                  1) Set SELinux zabbix_run_sudo boolean
                  setsebool -P zabbix_run_sudo=1
                  2) Compile the following *.te content into a *.pp with the following commands:
                  checkmodule -M -m -o allow_zabbix_full_sudo_access.mod allow_zabbix_full_sudo_access.te
                  semodule_package -o allow_zabbix_full_sudo_access.pp -m allow_zabbix_full_sudo_access.mod
                  module allow_zabbix_full_sudo_access 1.0;
                  require {
                  type power_unit_file_t;
                  type kernel_t;
                  type console_device_t;
                  type chkpwd_exec_t;
                  type system_dbusd_t;
                  type devlog_t;
                  type shadow_t;
                  type systemd_systemctl_exec_t;
                  type user_devpts_t;
                  type zabbix_agent_t;
                  type init_t;
                  class service { start status };
                  class process getpgid;
                  class unix_stream_socket connectto;
                  class dbus send_msg;
                  class chr_file { ioctl open write };
                  class capability { audit_write dac_override dac_read_search net_admin };
                  class file { execute execute_no_trans open read };
                  class netlink_audit_socket { create nlmsg_relay read write };
                  class sock_file write;
                  class unix_dgram_socket { connect create sendto write };
                  #============= zabbix_agent_t ==============
                  allow zabbix_agent_t chkpwd_exec_t:file execute_no_trans;
                  allow zabbix_agent_t console_device_t:chr_file { ioctl open write };
                  allow zabbix_agent_t devlog_t:sock_file write;
                  allow zabbix_agent_t init_t:dbus send_msg;
                  allow zabbix_agent_t init_t:process getpgid;
                  allow zabbix_agent_t init_t:unix_stream_socket connectto;
                  allow zabbix_agent_t kernel_t:unix_dgram_socket sendto;
                  allow zabbix_agent_t power_unit_file_t:service status;
                  allow zabbix_agent_t power_unit_file_t:service start;
                  allow zabbix_agent_t self:capability { audit_write dac_override dac_read_search net_admin };
                  allow zabbix_agent_t self:netlink_audit_socket { create nlmsg_relay read write };
                  allow zabbix_agent_t self:unix_dgram_socket { connect create write };
                  allow zabbix_agent_t shadow_t:file { open read };
                  allow zabbix_agent_t system_dbusd_t:dbus send_msg;
                  allow zabbix_agent_t system_dbusd_t:unix_stream_socket connectto;
                  allow zabbix_agent_t systemd_systemctl_exec_t:file { execute execute_no_trans };
                  allow zabbix_agent_t user_devpts_t:chr_file { open write };
                  3) Install the allow_zabbix_full_sudo_access.pp​ module:
                  semodule -i allow_zabbix_full_sudo_access.pp
                  • kmfreder
                    • Feb 2020
                    I applied the above selinux module and my error changed from "Permission Denied" to "sudo: account validation failure, is your account locked?" Any ideas on where to go from there?
                    • parkerm17
                      • Nov 2022
                      kmfreder: What does the following give you:
                      grep AVC /var/log/audit/audit.log
