Correct trigger expression for str.
  • dmalchikov
    • Sep 2018
    • 15
    Hi there,
    Try to get optimal alert settings (trigger expression)
    Anyone has such task?
    I have Item returning string with status: check_node[C:\Admin\Monitoring.xml] every 60s
    Result data like:
    2019-04-22 13:10:43 "Normal" Count="0"
    2019-04-22 12:57:43 "Error" Count="1"><Error Category="Node"DFS failed
    Current trigger
    Monitoring:{check_node[C:\Admin\Monitoring.xml].str(Error,#1)}=1 and {Monitoring:check_node[C:\Admin\Monitoring.xml].diff()}=0
    It's generate alert after first record with "Error" but
    I need alert only sends after 2nd of 3rd record contains "Error"
  • brunohl
    • Mar 2019
    • 215
    You could use something like
    {Monitoring:check_node[C:\Admin\Monitoring.xml].last(#1).str(Error)} = 1 and {Monitoring:check_node[C:\Admin\Monitoring.xml].last(#2).str(Error)} = 1 and {Monitoring:check_node[C:\Admin\Monitoring.xml].last(#3).str(Error)} = 1
    • dmalchikov
      dmalchikov commented
      Thanks for idea! But I still get alert at first error
  • brunohl
    • Mar 2019
    • 215
    Ah, I guess that since you're returning full log on every check it may be triggering because the last 3 checks contain error, but it's just one.
    You could try with count (https://www.zabbix.com/documentation...gers/functions) [⇒ count(10m,"error",eq) → number of values for last 10 minutes that equal 'error']
    Maybe something like:
    {Monitoring:check_node[C:\Admin\Monitoring.xml]count(10m,"Error",eq)} > 3
