Logging data from web page
  • danodemano
    • Jun 2014
    • 21
    Hello everyone,
    I have been working with Zabbix for some time now but have a really stupid question that I can't seem to find the answer to. I have some temperature sensors in my house logging to a MySQL database (not on the same server as Zabbix) that I would like to query. I have written a simple PHP page that returns ONLY the value of a specied sensor but I cannot figure out how to log/graph/trigger on this data. The web monitoring doesn't seem to do this (unless I'm missing something) and I didn't find anything useful in the external scripts. Any help would be greatly appreciated. Thanks!!
    Dan
  • aib
    • Jan 2014
    • 1615
    Zabbix server widely uses curl to get any data from http:// links.
    Do you mind to try something like:
    curl http://sensor_page.html | grep "Temperature:" | awk '{print $2;}'
    It will works if you have a simple page like
    Temperature: 32.9 °C
    If your command works, you can add it to UserParameter= in /etc/zabbix/zabbix_agent.conf file and then you can create Item/Triggers/Graphs with that Item in use.
    OK?
    Sincerely yours,
    Aleksey
    • danodemano
      • Jun 2014
      • 21
      Aleksey,
      Than k you very much for your reply! I think we are on the right track however when I attempt to query the custom parameter Zabbix is giving a not supported. Here is what I have done. Running the curl manually works correctly as expected:
      [root@zabbix zabbix_agentd.d]# curl http://arduino1.danodemano.com/get_data.php?sensor=1 | grep "Temperature:" | awk '{print $2;}'
        % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                       Dload  Upload   Total   Spent    Left  Speed
        0    18    0    18    0     0      3      0 --:--:--  0:00:05 --:--:--   189
      86.00
      So I created a new .conf file in /etc/zabbix/zabbix_agent.d and called it userparameters_temps.conf and it contains:
      #Arduino temperature monitoring
      UserParameter=arduino.temp1,curl http://arduino1.danodemano.com/get_data.php?sensor=1 | grep "Temperature:" | awk '{print $2;}'
      I restarted the agent but when I attempt to query the parameter I get a not supported error:
      [root@zabbix zabbix_agentd.d]# zabbix_agentd -t arduino.temp1
      arduino.temp1                                 [m|ZBX_NOTSUPPORTED]
      Is there something else I'm missing here? Thanks again, I really appreciate it!
      Dan
      • danodemano
        • Jun 2014
        • 21
        Nevermind, I can't edit the reply I made since it hasn't been posted yet. I set UnsafeUserParameters to a 1 and also increased my timeout value to 15 and it's working correctly now. Thanks again for the help, it's greatly appreciated!!
        Dan
        • aib
          • Jan 2014
          • 1615
          Anytime!
          Just for future use - curl has an option -s (silent)
          When you use that option, you will never seen the extra lines like
          Sincerely yours,
          Aleksey
          • danodemano
            • Jun 2014
            • 21
            Sweet! Didn't know that. It's been working perfectly though since I got everything up and running. I think I wan't to move the agent that's running the requests to my web server but that's another issue. I think I'm still getting some timeouts but the graph is looking awesome:
            Thanks again, I really do appreciate it!!!
            • aib
              • Jan 2014
              • 1615
              wow.
              it's really hot in your home.
              did you try to open windows?
              Sincerely yours,
              Aleksey
              • danodemano
                • Jun 2014
                • 21
                Haha, we don't run the AC much but the windows are always open.
