Mysql template fail on Plesk Odin. ZABBIX 4
  • akarim
    • Aug 2008
    • 33
    I have 50 servers monitored for MySQL using the mysql template.
    However, when I went to monitor a Plesk Odin server for the first time, it failed me.
    I think it's because of the mysqladmin.
    This is my conf in all Cpanel servers and work.
    /etc/zabbix/.my.cnf
    [mysql]
    host=localhost
    user=zabbix_admin
    password=mypassword
    socket=/var/lib/mysql/mysql.sock
    [mysqladmin]
    host=localhost
    user=zabbix_admin
    password=mypassword
    /etc/zabbix/zabbix_agentd.d/userparameter_mysql.conf
    UserParameter=mysql.status[*],echo "show global status where Variable_name='$1';" | HOME=/etc/zabbix mysql -N | awk '{print $$2}'
    UserParameter=mysql.ping,HOME=/etc/zabbix mysqladmin ping|grep alive|wc -l
    UserParameter=mysql.version,mysql -V
    /etc/zabbix/zabbix_agentd.conf
    Include=/etc/zabbix/zabbix_agentd.d/*.conf
    Error on mysql status (mysql.ping)
    Value "mysqladmin: connect to server at 'localhost' failed
    error: 'Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (13)'
    Check that mysqld is running and that the socket: '/var/lib/mysql/mysql.sock' exists!
    0" of type "string" is not suitable for value type "Numeric (unsigned)"
    mysql.status[Slow_queries]
    Value "ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (13)" of type "string" is not suitable for value type "Numeric (unsigned)"
  • diegofeijo
    • May 2019
    Try changing /etc/zabbix/.my.cnf to:
    [[B]client[/B]]
    user=zabbix_admin
    password=mypassword
