I have an ssh check that runs a script on a host that pings several hosts in a cluster. If everything is working then everything is fine. If one of the hosts in the cluster is down, the zabbix server triggers the alert and then the ssh check becomes not supported. The log entry is below:
[cluster:ssh.run[1,,3025]] became not supported: Cannot read data from SSH server
I've got my update interval at 90 secs. Is there anything else I can do to keep the item from disabling?
