system.localtime[local] returns different values
  • morrtz
    • May 2019
    Hi all,
    First post, please let me know if I'm not in the right location.
    I'm getting 2 different results when running system.localtime[local] -
    root@~ # zabbix_get -s xxxxxxx1 -k "system.localtime[local]"
    2019-05-02,05:56:45.974,-04:00
    root@~ # zabbix_get -s xxxxxxx2 -k "system.localtime[local]"
    2019-05-02,18:56:57.859,+09:00
    When I run only system.localtime I get the same epoch time, so this issue must be related to the local function in some way so I ran the command - date on both servers, they are set for JST.
    So I'm not really sure how the local function works or how it fetches the time exactly, I mean both the above times that returned are shown for similar timezone, but I want it to show the time relating to UTC as server #2 shown.
    Thanks!
  • morrtz
    • May 2019
    bumping to get some help!
    • Mike2K
      • Oct 2018
      • 60
      There's definitely some timezone config involved...have you tried running an ntpdate command just to make sure the time is correct ?
      • morrtz
        • May 2019
        Yes, the time in the server is correct.
        Need to know how Zabbix basically checks local time using the local function
        • LenR
          • Sep 2009
          • 1010
          Maybe this will help https://support.zabbix.com/browse/ZBX-15624 and/or https://support.zabbix.com/browse/ZBX-15301
          • morrtz
            • May 2019
            Thanks for the articles, but these seem irrelevant because they relate to version 4.0 triggering these issues, we are still on 3.0.3 (sorry for not mentioning in the original post!)
