Unable to start zabbix proxy
  • andaks
    • May 2014
    Hello there,
    i've been using zabbix server since version 1.8. Now i'm running zabbix v2.2.2 on Ubuntu 13.10.
    Lately I decide to create one zabbix proxy on other branch to connect with current zabbix server.
    However, after i complete install from source, i'm unable to start the zabbix proxy. Even i check at log dir, no log has been created.
    I'm using Ubuntu 13.10 with zabbix source V2.2.3. Here is the command i used.
    ./configure --enable-proxy --with-mysql --enable-agent --enable-ipv6 --with-net-snmp --with-libcurl
    I start zabbix-proxy using below command:
     service zabbix-proxy start
    and the respond is:
    zabbix-proxy stop/waiting
    I have configured all the configuration setting and pointing to mysql database.
    Hope experts can help me.
  • tchjts1
    • May 2008
    • 1605
    Have you checked the start script to make sure the path is correct?
    I personally don't use the start/stop scripts. Try starting it manually with something like this, but with your paths, of course:
    /usr/local/sbin/zabbix_proxy -c /usr/local/etc/zabbix_proxy.conf
    • aib
      • Jan 2014
      • 1615
      One more (helpful) thing: change Debuglevel=4 in /etc/zabbix/zabbix_proxy.cfg before starting the Zabbix Proxy.
      And then check /var/log/zabbix/zabbix_proxy.log to see any suspicious message.
      Sincerely yours,
      Aleksey
