Problems installing Zabbix-Template MongoDB
  • klm46
    • Mar 2018
    Hi @all,
    i'm a bit confused trying to install following template.
    The Zabbix Team has collected all official Zabbix monitoring templates and integrations.
    @ Github there are 5 files. I don't know exactly were to install which files. I imported the XML @ zabbix server (centos 7.5). Now we habe Windows-Servers with mongoDB. Is it enough to run the Powershell-Script which is one of the file? Are the other files only for a linux-based Mongo-Server? Or do i need to run the scripts also at zabbix server?
    Any help would be nice.
  • klm46
    • Mar 2018
    Anyone here to help me?
