I am trying to get a Powershell working inside a 4.2.1 zabbix. The template used to be made for an old evn. Its a discovery service
Original Content: https://share.zabbix.com/operating-s...cal-drive-iops
The powershell + Result:
$drives = Get-WmiObject win32_PerfFormattedData_PerfDisk_PhysicalDisk | ?{$_.name -ne "_Total"} |
Select Name;$idx = 1;write-host "{";write-host " `"data`":[`n";foreach ($perfDrives in $drives){if ($idx -lt $drives.Count){
$line= "{ `"{#DISKNUMLET}`" : `"" + $perfDrives.Name + "`" },";write-host $line;}elseif ($idx -ge $drives.Count){$line= "{ `"{#DISKNUMLET}`"
: `"" + $perfDrives.Name + "`" }";write-host $line;}$idx++;};write-host;write-host "]";write-host "}";
"data":[
{ "{#DISKNUMLET}"
: "0 C:" }
Even though i run this in a Json Validator and it comes out Validated. I get the following errors:
Invalid discovery rule value: cannot parse as a valid JSON object: invalid object format, expected opening character '{' or '[' at: '#< CLIXML
"data":[
{ "{#DISKNUMLET}" : "0 C: D:" }
<Objs Version="1.1.0.1" xmlns="http://schemas.microsoft.com/powershell/2004/04"><Obj S="p
Key:
system.run[%SystemRoot%\system32\WindowsPowerShell\v1.0\power shell.exe -executionpolicy ByPass -nologo -EncodedCommand {$DISCOVERDISK1}{$DISCOVERDISK2}{$DISCOVERDISK3}{$ DISCOVERDISK4}{$DISCOVERDISK5}]
"data":[
{ "{#DISKNUMLET}"
: "0 C:" }
"data":[
Key:
