hi
i defined an item named 'Used Memory in perc' in my OS template with 'vm.memory.size[pused]' as its key. i defined below trigger on it:
(({Template OS:vm.memory.size[pused].last()}>70) and ({Template OS:vm.memory.size[pused].time()}<000000 or {Template OS:vm.memory.size[pused].time()}>0630000)) or (({Template OS:vm.memory.size[pused].last()}>90) and ({Template OS:vm.memory.size[pused].time()}>000000 or {Template OS:vm.memory.size[pused].time()}<063000))
it mean if used memory went beyond 70 percent between 06:30 and 23:59 and beyond 90 percent between 00:00 and 06:29 then send an alert. i noticed that one of my hosts has 80% memory usage but trigger didn't activated. trigger is enabled and i see no errors anywhere. what should i do?
