I am configuring the zabbix agent on a RHEL 4 machine. I attempt to start it and it reports that it has failed.
Var/log/messages reports the following error:
kernel: zabbix_agentd[12915] trap divide error rip:32b6607927 rsp:7fbffff680 error:0
I installed and configured the agent using the following post:
uname -a:
Linux ######### 2.6.9-67.ELsmp #1 SMP Wed Nov 7 13:56:44 EST 2007 x86_64 x86_64 x86_64 GNU/Linux
using agents:
zabbix-agent-2.0.18-1.el5.x86_64.rpm
zabbix_agents_2.0.18.linux2_6.amd64.tar.gz
Appreciate any help you can give.
uname -a:
using agents:
