I have an issue and searching all day for a solution but cannot find.
I hope someone can help me with my issue Tomcat 8 cannot connect to Zabbix
CentOS 7
Zabbix server: 4.2.1
Zabbix Java Gateway runs on the Zabbix server.
Client server:
CentOS 7
Tomcat 8.5.35
When I want to connect from Zabbix to client-server I get the following error.
[root@zabbix scripts]# ./zabbix_get_java.sh localhost 10052 (ip) 9200 service:jmx:rmi:///jndi/rmi://(ip):9200/jmxrmi 'jmx["java.lang:type=Threading",ThreadCount]'
{"response":"failed","error":"Connection timed out: service:jmx:rmi:\/\/\/jndi\/rmi:\/\/(ip):9200\/jmxrmi"}
[root@zabbix scripts]# ./zabbix_get_jmx localhost 10052 (ip) 9200 'jmx["java.lang:type=Threading",ThreadCount]'
{"response":"failed","error":"No value for jmx_endpoint"}
I don't understand what I can do to fix this issue.
In my setenv.sh on the client-server I have:
CATALINA_OPTS="-Dcom.sun.management.jmxremote -Dcom.sun.management.jmxremote.port=9200 -Dcom.sun.management.jmxremote.ssl=false -Dcom.sun.management.jmxremote.authenticate=false"
When I check if the port is online on the client-server:
[root@cwh bin]# netstat -natp | grep 9200
tcp6 0 0 :::9200 :::* LISTEN 25808/java
What is wrong can someone help me, please.
IMPORTANT info the Client-server is behind a NAT with local IP to public IP by the router.
Can that be the issue for this problem?
regards,
CentOS 7
Client server:
CentOS 7
Tomcat 8.5.35
regards,
