Zabbix Server will not start
  • dazza007
    • May 2019
    Having setup my server and added my first few devices my zabbix server stopped and won't start. I have tried changing the memory settings according to http://alekseymyshkin.ru/zabbix-memo...-not-starting/
    I am on ubuntu 18 with Zabbix 4.2, some updated similar post on the forums show problems also with VMware, where I am using HyperV.
    Help please
    service zabbix-server start
    Job for zabbix-server.service failed because the control process exited with error code.
    See "systemctl status zabbix-server.service" and "journalctl -xe" for details.
    zabbix@:~$ service zabbix-server status
    ● zabbix-server.service - Zabbix Server
    Loaded: loaded (/lib/systemd/system/zabbix-server.service; enabled; vendor preset: enabled)
    Active: activating (auto-restart) (Result: exit-code) since Sat 2019-05-18 20:56:19 BST; 5s ago
    Process: 8682 ExecStart=/usr/sbin/zabbix_server -c $CONFFILE (code=exited, status=1/FAILURE)
    May 18 20:56:19 systemd[1]: zabbix-server.service: Control process exited, code=exited st
    May 18 20:56:19 systemd[1]: zabbix-server.service: Failed with result 'exit-code'.
    May 18 20:56:19 systemd[1]: Failed to start Zabbix Server.
    36119:20190518:195003.449 === Backtrace: ===
    36119:20190518:195003.450 11: /usr/sbin/zabbix_server(zbx_backtrace+0x4e) [0x561f8d44e77d]
    36119:20190518:195003.450 10: /usr/sbin/zabbix_server(__zbx_mem_malloc+0x180) [0x561f8d449a77]
    36119:20190518:195003.450 9: /usr/sbin/zabbix_server(+0x17be3a) [0x561f8d410e3a]
    36119:20190518:195003.450 8: /usr/sbin/zabbix_server(+0x1c5407) [0x561f8d45a407]
    36119:20190518:195003.450 7: /usr/sbin/zabbix_server(zbx_vector_ptr_append+0x1c) [0x561f8d45a5a8]
    36119:20190518:195003.450 6: /usr/sbin/zabbix_server(+0x184d8e) [0x561f8d419d8e]
    36119:20190518:195003.450 5: /usr/sbin/zabbix_server(DCsync_configuration+0xf8e) [0x561f8d41e25f]
    36119:20190518:195003.450 4: /usr/sbin/zabbix_server(MAIN_ZABBIX_ENTRY+0x72e) [0x561f8d2d3f83]
    36119:20190518:195003.450 3: /usr/sbin/zabbix_server(daemon_start+0x2f0) [0x561f8d44debc]
    36119:20190518:195003.450 2: /usr/sbin/zabbix_server(main+0x305) [0x561f8d2d383f]
    36119:20190518:195003.450 1: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7) [0x7faf0cad7b97]
    36119:20190518:195003.450 0: /usr/sbin/zabbix_server(_start+0x2a) [0x561f8d2d28ea]
    36148:20190518:195013.579 Starting Zabbix Server. Zabbix 4.2.1 (revision 92832).
    36148:20190518:195013.580 ****** Enabled features ******
    36148:20190518:195013.580 SNMP monitoring: YES
    36148:20190518:195013.580 IPMI monitoring: YES
    36148:20190518:195013.580 Web monitoring: YES
    36148:20190518:195013.580 VMware monitoring: YES
    36148:20190518:195013.580 SMTP authentication: YES
    36148:20190518:195013.580 Jabber notifications: NO
    36148:20190518:195013.580 Ez Texting notifications: YES
    36148:20190518:195013.580 ODBC: YES
    36148:20190518:195013.581 SSH2 support: YES
    36148:20190518:195013.581 IPv6 support: YES
    36148:20190518:195013.581 TLS support: YES
    36148:20190518:195013.581 ******************************
    36148:20190518:195013.581 using configuration file: /etc/zabbix/zabbix_server.conf
    36148:20190518:195013.615 current database version (mandatory/optional): 04020000/04020000
    36148:20190518:195013.615 required mandatory version: 04020000
    36148:20190518:195014.522 __mem_malloc: skipped 0 asked 256 skip_min 18446744073709551615 skip_max 0
    36148:20190518:195014.522 [file:dbconfig.c,line:94] __zbx_mem_malloc(): out of memory (requested 256 bytes)
    36148:20190518:195014.522 [file:dbconfig.c,line:94] __zbx_mem_malloc(): please increase CacheSize configuration parameter
    36148:20190518:195014.522 === memory statistics for configuration cache ===
    36148:20190518:195014.522 free chunks of size 24 bytes: 28
    36148:20190518:195014.522 free chunks of size 40 bytes: 3
    36148:20190518:195014.522 free chunks of size 48 bytes: 1
    36148:20190518:195014.522 free chunks of size 56 bytes: 6
    36148:20190518:195014.522 free chunks of size 64 bytes: 1
    36148:20190518:195014.522 free chunks of size 72 bytes: 1
    36148:20190518:195014.522 free chunks of size 176 bytes: 1
    36148:20190518:195014.522 min chunk size: 24 bytes
    36148:20190518:195014.522 max chunk size: 176 bytes
    36148:20190518:195014.522 memory of total size 8388232 bytes fragmented into 69451 chunks
    36148:20190518:195014.522 of those, 1488 bytes are in 41 free chunks
    36148:20190518:195014.522 of those, 7275544 bytes are in 69410 used chunks
    36148:20190518:195014.522 ================================
    36148:20190518:195014.522 === Backtrace: ===
    36148:20190518:195014.522 11: /usr/sbin/zabbix_server(zbx_backtrace+0x4e) [0x55feeafaf77d]
    36148:20190518:195014.522 10: /usr/sbin/zabbix_server(__zbx_mem_malloc+0x180) [0x55feeafaaa77]
    36148:20190518:195014.522 9: /usr/sbin/zabbix_server(+0x17be3a) [0x55feeaf71e3a]
    36148:20190518:195014.522 8: /usr/sbin/zabbix_server(+0x1c5407) [0x55feeafbb407]
    36148:20190518:195014.522 7: /usr/sbin/zabbix_server(zbx_vector_ptr_append+0x1c) [0x55feeafbb5a8]
    36148:20190518:195014.522 6: /usr/sbin/zabbix_server(+0x184d8e) [0x55feeaf7ad8e]
    36148:20190518:195014.522 5: /usr/sbin/zabbix_server(DCsync_configuration+0xf8e) [0x55feeaf7f25f]
    36148:20190518:195014.522 4: /usr/sbin/zabbix_server(MAIN_ZABBIX_ENTRY+0x72e) [0x55feeae34f83]
    36148:20190518:195014.522 3: /usr/sbin/zabbix_server(daemon_start+0x2f0) [0x55feeafaeebc]
    36148:20190518:195014.522 2: /usr/sbin/zabbix_server(main+0x305) [0x55feeae3483f]
    36148:20190518:195014.523 1: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7) [0x7f8ba2c05b97]
    36148:20190518:195014.523 0: /usr/sbin/zabbix_server(_start+0x2a) [0x55feeae338ea]
  • steeladept
    • Sep 2018
    • 69
    I am guessing these two lines point to your problem:
    Edit the config file to allocate more memory and see if that solves your issue.
