I created a template that does MT4 service TCP connection checks to a list of IPs on ports 443 and 1950. I assigned this template to the host of Zabbix server in order for it to perform these checks. On this temlate I had same amount of tiggers created.
Yesterday afternoon I disabled on the template all those tiggers. During the night it was raining SMSs from the disabled triggers and I went on the Zabbix server host and double cheked that triggers were disabled.
I had to export the template and delete it and delete also the triggers from the Zabbix server host.
We we received SMSs for disabled triggers?
When we enable/disable triggers is it logged in any log file because I need to have proof that I disabled them?
Thanks!
Thanks!
