Hi There,
Please give me some feedback on the issue of "how to monitor the proxy-host itself".
I monitor a quite large remote site ( 250 hosts / 750 VPS) through a single proxy.
Communication between server and proxy is over an IVPN with limited throughput and a firewall that limits my access.
So I am stuck with a passive proxymode, but that works 95%.
The proxy host itself is monitored through a local agent, connected from the proxy process on the proxy host. ( 127.0.0.1:10050 )
But the server sometimes loses connection , and complains about 5 minutes without updates from the proxy, and it always auto resolves itself.
The issue could be the VPN or the hourly cleanup task @proxy
Can I monitor the connection to the proxy host, from the Zabbix server itself?
Without creating a second host that is actually the same as the one already defined ?
With 1 host i can only see 1 switch to select "Monitored by proxy/ No proxy ".
( Version 3.4 on server and proxy, Proxy running on Ubuntu 16.04 )
Regards M-H
Regards M-H
