Email Alerts/Notificiations stopped after doing MYSQL Partitioning
  • dfisicaro
    • Jul 2017
    • 16
    Hi Everyone,
    I'm setting up a new Zabbix Environment and all my alerting was working perfectly.
    I completed the MYSQL Partitioning earlier and now when i restarted Zabbix my Email alerts have suddenly stopped.
    The actual problem and event shows in the Portal like normal though, i just don't get an email alert.
    I'm using Zabbix 4.0.6.
    Any suggestions would be appreciated.
    Thanks,
    Daniel
  • dfisicaro
    • Jul 2017
    • 16
    My AutoRegistration Emails are all working fine from Zabbix. Tested that for the ones I have created by deleting some hosts and seeing if the email alerts work.
    And I tested sending emails from the Zabbix Server via our mail relay host. So that is all OK.
    I'll try re-creating the Action Rules for the Triggers.
    • dfisicaro
      • Jul 2017
      • 16
      It seems to have started to work again once I re-created the Action Rule Triggers.
      Testing it some more.
