Assets cache directory is not writable.
  • wifi75
    • Apr 2018
    • 45
    Hello on my server centos after last zabbix server update, isn't to possbile login...
    what can I do?
  • edwardcc
    • May 2019
    Same problem here, ubuntu 1804, and rpi
    updating from 4.0.7 to 4.0.8
    using google the only thing I can find is
    which says
    "Since Zabbix 4.2.2, write permissions to the assets directory are required for the web server user."
    I can find the file is added here
    https://git.zabbix.com/projects/ZBX/...chewarning.php
    • kosmas
      • May 2019
      Same here!
      Two CentOS 7 updated to 4.0.8-1 both have the same problem.
      Insufficient file system permissions.
      • Assets cache directory is not writable.
      • ma-kom
        • May 2019
        Did the trick for me:
        sudo chmod -R 777 /usr/share/zabbix/assets
        • senatorfoo
          • May 2019
          777 is not ideal for just about anything. Change the ownership of the directory to the frontend and leave it at 755. Debian would be www-data
          chown www-data:www-data /usr/share/zabbix/assets
          • efisher
            • May 2019
            That worked for me, but now I'm having an issue where none of the fonts are showing up with the graphs. It seems that I might be missing some assets after upgrading, but not sure. This was upgraded via RPM on Centos 7. Downgrading to 4.0.7 resolves issue, but something is wrong with 4.0.8.
            • Pioxis
              Pioxis commented
              I have the same issue with that graphs. I had to downgrade from 4.2.2 to 4.2.1.
          • snickerjp
            • May 2019
            Only Change
            before:
            $ ls -ld /usr/share/zabbix/assets
            drwxr-xr-x 6 root root 55 May 29 13:45 /usr/share/zabbix/assets
            $ ls -ld /usr/share/zabbix/assets/*
            drwxr-xr-x 2 root   root      6 May 28 18:27 /usr/share/zabbix/assets/fonts
            drwxr-xr-x 2 root   root   4096 May 29 13:44 /usr/share/zabbix/assets/img
            drwxr-xr-x 2 root   root     85 May 29 13:44 /usr/share/zabbix/assets/styles
            after:
            sudo chmod 777 /usr/share/zabbix/assets
            drwxrwxrwx 6 root root 55 May 29 13:45 /usr/share/zabbix/assets
            drwxr-xr-x 4 apache apache   29 May 29 13:45 /usr/share/zabbix/assets/10am2h0 #<- add write from apache
            because:
            • wifi75
              • Apr 2018
              • 45
              My server it is Centos 7
              that line to send by terminal are valid?
              • kosmas
                kosmas commented
                Hi wifi75, the command is valid, but it is not security wise to change the permissions of a directory to 777.
                I have temporarily used this workaround until there is a better and more secure solution.
            • Husnu Demir
              • May 2019
              cd /usr/share/zabbix/
              chown -R www-data:www-data assets/
              This would be more secure. Apache2 works with www-data user.
              hdemir.
              • Pioxis
                • May 2019
                hdemir.
                Hello, that option is not working for me.
                I have zabbix on ubuntu and still I don't have fonts for my monitors.
                What I have to do to fix it?
                • Pioxis
                  Pioxis commented
                  Fonts for me now working. Folder /assets/fonts was empty and I copied there default font from /zabbix/fonts.
              • wifi75
                • Apr 2018
                • 45
                hdemir.
                not work see below:
                • Husnu Demir
                  • May 2019
                  OK. I have been using Debian and my apache servers user is www-data. U should use your web user. I found my user like that;
                  # ps -ef | grep apache2
                  root 13905 1 0 May28 ? 00:00:00 /usr/sbin/apache2 -k start
                  www-data 32975 13905 0 06:25 ? 00:00:03 /usr/sbin/apache2 -k start
                  There may be other ways. Change the username with "www-data:www-data"
                  hdemir.
                  • Husnu Demir
                    • May 2019
                    Also, this may help;
                    https://stackoverflow.com/questions/...wned-by-apache
                    • wts_tim
                      • May 2019
                      I am currently running CentOS 7, Zabbix updated these four packages last night and no longer able to access the log in page as i see the same error message above.
                      May 29 03:24:38 Updated: zabbix-web-mysql.noarch 4.0.8-1.el7
                      May 29 03:24:40 Updated: zabbix-web.noarch 4.0.8-1.el7
                      May 29 03:24:41 Updated: zabbix-server-mysql.x86_64 4.0.8-1.el7
                      May 29 03:24:41 Updated: zabbix-agent.x86_64 4.0.8-1.el7
                      I have tried changing the permissions to 777 and changing the owner to apache but this makes no difference for my setup.
                      • sph919
                        • Jan 2019
                        • 38
                        #15
                        What permissions are shown with ls- la /usr/share/zabbix/ ?
