Ping check on external host
  • yash_25
    • May 2019
    • 41
    I want to ping an external host where there is no zabbix agent installed on it.
    I have created a user parameter on zabbix server
    UserParameter=Ping_check[*],/sbin/fping $1 -t 100 | grep alive | wc -l
    I have created an item on Zabbix UI. Please check the below attached file
    After creating the item it is showing this error as not supported(dont know why)
Name:	item error.PNG
    I have created a trigger with the below expressions
    {Zabbix server:Ping_check.nodata(5m)}=1
    {Zabbix server:Ping_check.last()}=0
    I am not sure why the item is showing as unsupported and what expression should be used in the trigger. could you please help me with this
