Monitoring mobile devices on DHCP and remote networks
  • klowet
    • Jun 2019
    • 10
    Hi
    How can we monitor mobile devices which are hopping on different networks like laptops and Windows tablets?
    Their agent should be configured as Active. But how can I configure the devices in Zabbix? When I add a new Host, I have to configure the IP address of the agent, but that will always be different.
  • brunohl
    • Mar 2019
    • 215
    I have nothing like it, but as far as I see, the easiest way for you to do it would be to use Agent Active on your hosts and set AutoRegistration on them. Also, they need to reach your server somehow, so if you have a lot of remote hosts I guess your zabbix server should be public.
