Zabbix processes 100% CPU, EBADF Error
  • rich1985
    • May 2012
    Hi Everyone,
    looking for a bit of help, the past few days our zabbix server has been running at 100% cpu,
    Top shows that it is always the zabbix server processes that are using the cpu, restarting the server solves the issue for a few minutes then the issue persists again
    doing an strace on the processes shows the follow error constantly repeated.
    select(1, [0], [], [], {0, 995327}) = -1 EBADF (Bad file descriptor)
    gettimeofday({1404332372, 164449}, NULL) = 0
    gettimeofday({1404332372, 164787}, NULL) = 0
    select(1, [0], [], [], {0, 994948}) = -1 EBADF (Bad file descriptor)
    gettimeofday({1404332372, 164834}, NULL) = 0
    gettimeofday({1404332372, 164852}, NULL) = 0
    select(1, [0], [], [], {0, 994883}) = -1 EBADF (Bad file descriptor)
    gettimeofday({1404332372, 164893}, NULL) = 0
    gettimeofday({1404332372, 164910}, NULL) = 0
    select(1, [0], [], [], {0, 994825}) = -1 EBADF (Bad file descriptor)
    gettimeofday({1404332372, 164952}, NULL) = 0
    gettimeofday({1404332372, 164972}, NULL) = 0
    select(1, [0], [], [], {0, 994763}) = -1 EBADF (Bad file descriptor)
    gettimeofday({1404332372, 165014}, NULL) = 0
    gettimeofday({1404332372, 165031}, NULL) = 0
    select(1, [0], [], [], {0, 994704}) = -1 EBADF (Bad file descriptor)
    gettimeofday({1404332372, 165072}, NULL) = 0
    The system time on the server is correct, The zabbix server log shows nothing particularly wrong, however I notice there are active check entries for a host that has been removed?
    Any assistance is greatly received!
