How to spread HTTP Checks in time?
  • hex
    • Jun 2019
    I am trying to use ZABBIX for statistics monitoring of my appication.
    I have LLD that creates thousents of items. Items are HTTP Agent checks that retrive value from a url once in 12h.
    Current siguration is that all checks start executing in nearly the same time overloading zabbix queue and web server.
    Any feature that allows me to spread them out?
  • brunohl
    • Mar 2019
    • 215
    If I were you, what I would do is generate a period to check in the LLD itself, then return it and use its value on a scheduled interval. I checked it and it's supported (https://www.zabbix.com/documentation...ros/lld_macros)
    • hex
      • Jun 2019
      To put macro in update interval or in custom intervals?
      I want same update interval for all items. Just not triggering those items at the same time.
      Or you ment I can generate interval for each item in 10-14h randge so they would defuse after some time?
      • brunohl
        • Mar 2019
        • 215
        You should use a custom interval, in a Scheduled Format.
        So, lets say your discovery script should generate a random number, from 0 to 11 and then, add 12 (for the second check) and then return them concatenated in a parseable string. Something like this:
        - Discovery => Generates number 4 => So, you have 4 and 16 (12h apart, your two checks) => The return of the command should be something like h4,h16 => Your key will be executed 12h apart.
        I guess that this way it would work. You could make small adjustments to enter in minutes also.
        • hex
          • Jun 2019
          Thanks a lot!
          Works.
          (but I'm having little problem with null values https://support.zabbix.com/browse/ZBX-16232 )
          • brunohl
            • Mar 2019
            • 215
            But you want to create the item if the marcro interval is null? What should be the interval?
            • hex
              • Jun 2019
              null. I want to disable that item.
              for basic interval I can enter 0 to disable it. There is no value that I am aware of that I can enter in scheduling interval to disable it.
              • brunohl
                • Mar 2019
                • 215
                Maybe you should use filters (like the File System Discovery template)
                • hex
                  • Jun 2019
                  That would remove items, right?
                  I don't want them removed. I want items to stay because of history, just not to collect data anymore.
                  • brunohl
                    • Mar 2019
                    • 215
                    OK, so why don't you create a custom interval with a wide range and let it run into errors and disable the item? The history will be manteined
                    • hex
                      • Jun 2019
                      wide range? errors? How to disable item from LLD ?
                      • brunohl
                        • Mar 2019
                        • 215
                        When the item tries to do the check, it will fail and it will be marked as "Not Supported", so the item continues to exist.
                        • hex
                          • Jun 2019
                          yea thats what I'm doing now but it's not very ellegant solution.
                          • brunohl
                            • Mar 2019
                            • 215
                            Yeah, I know. But as the way that Zabbix is structured it doesn't seem to be made to work the way you want.
