perf_counter on Hyper-V - where is the failure?
  • Daniel4711
    • Jul 2014
    • 127
    at first: Sorry for my bad English
    i´m Using the Zabbix 2.2 Appliance and want to query the following Performance Counter:
    6132 = Virtuelles Hyper-V-Speichergerät
    HTML Code:
    perf_counter[6132(d:-vm-w01ex01-Virtual Hard Disks-Server2008R2-Exchange.vhdx)\Gelesene Bytes/s]
    This query is working fine directly on the zabbix console (see attached Image), but i got an Error in the frontend!
    Here´s the Log:
    HTML Code:
     5540:20140704:160352.818 cannot get required buffer size for counter path '6132(d:-vm-w01ex01-Virtual Hard Disks-Server2008R2-Exchange.vhdx)\Gelesene Bytes/s': [0xC0000BC4] Der angegebene Leistungsindikatorpfad konnte nicht interpretiert werden.
      5540:20140704:160352.818 active check "perf_counter[6132(d:-vm-w01ex01-Virtual Hard Disks-Server2008R2-Exchange.vhdx)\Gelesene Bytes/s]" is not supported
      5540:20140704:160352.818 cannot get required buffer size for counter path '6132(d:-vm-w01ex01-Virtual Hard Disks-Server2008R2-Exchange.vhdx)\Geschriebene Bytes/s': [0xC0000BC4] Der angegebene Leistungsindikatorpfad konnte nicht interpretiert werden.
      5540:20140704:160352.818 active check "perf_counter[6132(d:-vm-w01ex01-Virtual Hard Disks-Server2008R2-Exchange.vhdx)\Geschriebene Bytes/s]" is not supported
    I have attached another File with a Screenshot of the Configuration.
    Plz help!
  • ingus.vilnis
    • Mar 2014
    • 908
    Hi Daniel,
    You have incorrect key syntax in Zabbix frontend as I see in your screenshot. The \ is missing in the beginning and d: is used instead of D:.
    Please use the exact same key that you used with zabbix_get and try again.
    Best Regards,
    Ingus
    • Daniel4711
      • Jul 2014
      • 127
      Argh.. such a stupid typo..
      Many thanks for the quick reply!!
      Many greetings from Germany
      Daniel
