Notification abut disabled services
  • szremo
    • Jul 2018
    • 12
    Dear Zabbix forum,
    I would like to ask you about following problems.
    I have installed Zabbix(4.2.1) monitoring in my infrastructure, generally everything works fine except one thing.
    Zabbix show me a lots of notification about not working services on windows machines.
    Fore example :
    ​ Click image for larger version
Name:	Screenshot 2019-06-11 at 11.03.28.png
    But those services has been switched to disabled.
    Even if I will restart Zabbix Agent it still blinking. I know that I can remove check from server, but my question is. Is there any option to force Zabbix to recheck if services is switched to disabled remove alert ?
    Or maybe discover process of startup type of any services is only once, during adding to monitoring server.
  • Atsushi
    • Aug 2013
    • 2028
    Try executing Windows service discovery.
    Display a list of discovery rules by "Template OS Windows" on that host, check the check box to the left of the "Windows service discovery" discovery rule, and click the "Check Now" button.
    In a few minutes Zabbix server should get the latest Windows service list again.
    • szremo
      • Jul 2018
      • 12
      Atsushi thanks for your answer, I did that but int not helps. still the same status
      • Atsushi
        • Aug 2013
        • 2028
        How long is the "Keep lost resources period" time in the discovery rule? The default setting is 30 days, so it will not be deleted until 30 days have passed. If you want to delete items or triggers that you no longer need to monitor quickly, try temporarily setting a shorter time.
        • szremo
          • Jul 2018
          • 12
          It was set to 30d I switched it to 7d. We will see if it helps
