I have a problem with all my web scenarii since I've migrated from 1.8.5 to 2.2.2.
I use a DMZ proxy to test several IP typically in HTTPS. It worked perfectly in 1.8.5 but it doesn't work anymore in 2.2.
Typically a web scenario in composed with a " home " step such as : https://xxx.xxx.xxx.xxx:1010
and a unique trigger is used such as :
I don't have any error on my trigger (green tick) but the lastest data panel give me an error "Timeout was reach" and the alert corresponding with the trigger appear as an issue on my dashboard.
Is there a change between 1.8 and 2.2 which could explain this problem ?
Thank you per advance.
{MyHost:web.test.fail[Availability MyScenario].sum(#5)}>4
