How to handle break lines in SNMP TRAPs contents
  • Leo.SP
    • Jan 2019
    Dear,
    I have a scenario and I need your help. I am creating a monitoring that will receive SNMP TRAPS and will send a HTTP POST with several values ​​to a WEB server, this WEB server has the function of consolidating events.
    It turns out that I'm having some formatting problems in the received values, see if they can help me;
    Below I have the format of how the TRAP arrives;
    06/07/2019 06:15:25 PM
    18:15:23 2019/06/07 PDU INFO:
    TRAP notificationtype
    version 0
    receivedfrom UDP: [127.0.0.1]: 30468 -> [127.0.0.1]: 162
    errorstatus 0
    messageid 0
    community public
    transactionid 23690
    errorindex 0
    requestid 0
    VARBINDS:
    DISMAN-EVENT-MIB :: sysUpTimeInstance type = 67 value = Timeticks: (55) 0: 00: 00.55
    SNMPv2-MIB :: snmpTrapOID.0 type = 6 value = OID: IF-MIB :: linkUp.0.33
    IF-MIB :: linkUp type = 4 value = STRING: "eth0"
    SNMP-COMMUNITY-MIB :: snmpTrapCommunity.0 type = 4 value = STRING: "public"
    SNMPv2-MIB :: snmpTrapEnterprise.0 type = 6 value = OID: IF-MIB :: linkUp
    Through actions and media I will send the values ​​in the pattern below;
    {"name_trigger": "{TRIGGER.NAME}",
    "id_trigger": "{TRIGGER.ID}",
    "zabbix_source": "ZBX_HOM_01",
    "event_start": "{EVENT.DATE} {EVENT.TIME}",
    "item_value": "{ITEM.LASTVALUE}",
    "nm_host": "{HOST.HOST}",
    "ip_host": "{HOST.IP}",
    "application": "{$ HOS_APLICACAO}",
    "application_function": "{$ HOS_APLICACAO_FUNCAO}",
    "severity": "{TRIGGER.SEVERITY}",
    "id_zabbix": "{EVENT.ID}",
    "event_status": "{EVENT.STATUS}",
    "event_zabbix": "{EVENT.VALUE}",
    "event_age": "{EVENT.AGE}"}
    This works very well for all types of items (keys) that I have already used, but for SNMP TRAPs is not good, this is because the TRAPS arrive with the broken lines as in the example below;
    {"name_trigger": "SNMP TRAP TRIGGER",
    "id_trigger": "25332",
    "event_start": "2019.06.07 18:15:25",
    "item_value": "18:15:23 2019/06/07 PDU INFO:
    version 0
    errorstatus 0
    messageid 0
    community public
    transactionid 23690
    errorindex 0
    requestid 0
    VARBINDS:
    SNMPv2-MIB :: snmpTrapEnterprise.0 type = 6 value = OID: IF-MIB :: linkUp ",
    "nm_host": "Zabbix server",
    "ip_host": "127.0.0.1",
    "application": "{$ HOS_APP}",
    "application_function": "{$ HOS_APP_FUN}",
    "severity": "high",
    "id_zabbix": "10417911",
    "event_status": "PROBLEM",
    "event_zabbix": "1",
    "event_age": "0m"}
    Can you tell me if there is any way I can break line breaks only from the value received by the {ITEM.LASTVALUE} macro to get all the value received on the same line? Do you have a method (via preprocessing) to handle these line breaks? To be clearer, I'd like you to stay on the way down;
    "item_value": "18:15:23 2019/06/07 PDU INFO: notificationtype TRAP version 0 receivedfrom UDP: [127.0.0.1]: 30468 -> [127.0.0.1]: 162 errorstatus 0 messageid 0 community public transactionid 23690 errorindex 0 mb :: snmpTrapOID.0 type = 6 value = OID: IF-MIB :: linkUp.0.33 VARBINDS: DISMAN EVENT-MIB :: sysUpTimeInstance type = 67 value = Timeticks: (55) 0: 00: 00.55 SNMPv2-MIB :: snmpTrapOID.0 SNMP-MIB :: snmpTrapCommunity.0 type = 4 value = STRING: "public" SNMPv2-MIB :: snmpTrapEnterprise.0 type = 4 value = OID : IF-MIB :: linkUp",
    "severity": "high",
    "event_age": "0m"}
    Sorry for translation errors
    Regards,
