zabbix agent is intermittent down for a few minutes
  • robertchen
    • Jun 2014
    • 39
    please help, when I got to the agent log, I see nothing.
    I can do both ways telnet zbx server 10051, zbx agent 10050.
    But I got alerts like: Zabbix agent on *MYHOST* is unreachable for 5 minutes
    please see the pic attached:
  • filipp.sudanov
    • May 2014
    • 137
    I would probably suggest to check the following:
    - Any Antivirus/Firewall software runing on agent - zabbix opens and closes TCP connections all the time and sometimes firewalls don't like it
    - May be too high CPU load on the monitored machine
    - Isn't it a network problem, any routers that may get restated on they own?
    You can add a simple check with icmpping of that machine. This check will not be dependent on zabbix agent. Afterwards you'll be able to compare the graphs - if agent ping and icmpping will be missing together, or not.
