java JMX monitoring via zabbix java gateway
  • jaksky
    • Oct 2013
    • 10
    I am trying to monitor java app Apache Kafka Server from zabbix via zabbix java gateway and I am a bit struggling with zabbix set up. I was able to monitor JVM standard metrics like LoadedClassCount etc. But I cannot find proper setup for Kafka metrics.
    My zabbix java gateway JMX key is following:
    jmx["kafka.server.BrokerTopicMetrics:type=AllTopicsMes sagesInPerSec",Count]
    I tried various combination of JMX string but so far with no luck. Any hints what might be wrong?
    It seems like JMX objects are nested.
    In the gateway log I am getting exception: javax.management.InstanceNotFoundException:
    Thx
  • kamyar
    • Jul 2014
    There is no need to use double quotes:
    jmx[kafka.server.BrokerTopicMetrics:type=AllTopicsMessagesInPerSec,Count]
    • jaksky
      • Oct 2013
      • 10
      Following works for me
      jmx["\"kafka.server\":type=\"BrokerTopicMetrics\",name=\"AllTopicsMessagesInPerSec\"", Count]
