Hi, we just install an new agent in an centos 7 machine, but when we start it, it keeps repeating this error in the logs :
28485:20190613:160530.893 loading modules failed, exiting...
28492:20190613:160541.137 Starting Zabbix Agent [Zabbix server]. Zabbix 4.2.0 (revision 91746).
28492:20190613:160541.137 **** Enabled features ****
28492:20190613:160541.137 IPv6 support: YES
28492:20190613:160541.137 TLS support: YES
28492:20190613:160541.137 **************************
28492:20190613:160541.137 using configuration file: /etc/zabbix/zabbix_agentd.conf
28492:20190613:160541.142 cannot initialize module "zbxpcp.so"
28492:20190613:160541.142 loading modules failed, exiting...
We have another centos 7 machine ( also with proxy ) that is working fine, the only diference was the packages instaled, We would like to know witch package is missing and causing this error. Obs: pcp is not installed on eather machines ( the machine that is working dont have it ). Should I install it anyway ? Where can I get the list of required packages/libs for the zabbix agent ? Obs: this machine also have an working fine proxy.
Regards,
Wagner.
