Hi.
I've googled around and seems an old topic, but couldn't find the correct way to handle it.
I'd like to monitor an ISPConfig host which has a *lot* of bind mount points for local directories. Like this (from mtab):
I found I should change the "File system auto discovery" rule in order to exclude mount types I'd like to remove. So this is the default regexp in Zabbix 2.2:
which should already exclude bind mounts, which have mount type=none. In fact if I make a test with the regexp tester built into Zabbix webui the none value returns FALSE.
So why is it still showing all those mountpoints?
thanks
/var/log/ispconfig/httpd/domain.com /var/www/clients/client207/web243/log none rw,bind 0 0
^(btrfs|ext2|ext3|ext4|jfs|reiser|xfs|ffs|ufs|jfs|jfs2|vxfs|hfs|ntfs|fat32|zfs)$
thanks
