Agent: UserParameter, execution in parallel or queued order?
  • Flowsen
    • Jul 2014
    Dear Community,
    since it is not possible to pass multiple values to the Zabbix Server using UserParameter I am struggling with getting the best performance.
    Can someone tell me if the UserParameter calls are done in queue or if multiple UserParameter are processed in parallel?
    For example in zabbix_agentd.conf I have:
    UserParameter=harddisk.discovery,/home/zabbix_harddisk.sh
    UserParameter=harddisk.data[*],/home/zabbix_harddisk.sh $1 $2
    Currently I receive a list of all physical harddisks with the first line - thats just fine.
    On the second line I get different SMART values and information of the drive.
    $1 is the harddrive $2 the value, for example:
    /home/zabbix_harddisk.sh /dev/sda smart_value_5
    /home/zabbix_harddisk.sh /dev/sda smart_value_194
    /home/zabbix_harddisk.sh /dev/sda smart_value_196
    and so on...
    It works well, but smartctl and other operations are executed multiple times which would not be necessary if zabbix server accepts more than one return value.
    My aproach is to cache all informations as soon as any of the above smart_values is requested. This would work perfectly if zabbix agentd does not run multiple UserParameter simultaneously.
    Does anyone know if zabbix proccesses these external command in a queue or parallel?
    Thanks!
  • jan.garaj
    • Jan 2010
    • 506
    I don't know answer for your question, but I idea for you:
    Use zabbix_sender and then you can send many values in one go. And you can still call script (with zabbix_sender) as userparameter script.
    • Flowsen
      • Jul 2014
      Thats a good idea, thank you.
      I didn't know that it is possible to send multiple items with zabbix-sender.
      So basically I should keep:
      to get my list of harddisks and afterwards use
      and pass with $1 the harddisk i received with harddisk.recovery
      All values I need are now sent with zabbix-sender!
      This solved my problem - you really made my day!
